Any idea when S26 will be supported ? Or is it already ?. I haven’t tried the current installer and rather wait for instructions by Chaos.
If you have R25 and S26 installed parallelly, you can just copy the corona folder from R25 plugins and paste it over to S26 plugins.
In my tests, Corona V8 ran fine in S26, with one medium flaw: you cannot load textures directly (they will render black) but you have to load them in the Corona bitmap shader.
Guess there will be a fix for that pretty soon.
HTH
Michael
No Work for me
stand by
Thanks a lot for this tip, adding them to the Corona Bitmap Shader works just fine even for the Sky Object.
Hm, a Q in this regard,
Is it possible & viable for every Texture slot to get additional Corona’s Bitmap & Color Correct feature (w/ check box)?
Especially, since those are most commonly used (~ 90% in my cases) and setting all up takes quite some time.
If yes, I’ll be sure to request/suggest a feature ![]()
We should have support coming for S26 possibly tomorrow. No promises though ![]()
And daily build with S26 is here: https://forum.corona-renderer.com/ Chaos Corona 9 for Cinema 4D daily builds - Changelog #msg197729
You ARE fast!
Thx.
anyone have success with the daily9 update? I’m getting lots of errors on S26 startup and missing Corona plugins once it’s up and running
It’s working fine here.
I just unpacked everything, then copied the S26 plugin and pasted it in its place.
No problems here, I just installed S or R 26 (it doesn’t seem to know what it wants to be called ;), then ran the new daily build installer of Corona 9, made sure to pick Custom so I could check 26 was selected, and presto. Can you share screenshots of the errors you are getting, and confirm the steps you followed to install Corona 9?
