Hi folks. I’ve come back to an old project and previously, I’m sure the model rendered correctly in Corona 5. I’ve since tried it out in Corona and apart from some areas of the model which are fine, everything else renders black. I thought Corona could make full use of C4d shaders?
Regards
Ron
Could you be tiny bit more specific what C4D shader(s) you were using and in which context?
Michael
Did you pull up the Texture Manager window to ensure the any textures the old scene used are still linked? Are you sure you didn’t use the Convert Scene button? This will totally ruin any materials you had, especially any that use the Reflectance Channel.
