Hi
Is there a way to get the render region in C4D to be recognised when uploading to CC? It’s dead useful for testing a small patch.
Many thanks!
Hi
Many thanks!
Hi @pali_rao ,
Thanks for reaching out to us! We’ll check the feature how it works with Chaos Cloud and will follow up here.
Bests,
Vladie
Hey, Pali,
Thank you for the report. This option is missing indeed into the core v.5 and up; however,
the First option: Export the vrscene file → Create Render region (RR) and open Render Settings → V-Ray → V-Ray Common → Translator → Untick Render and check the Export to a vrscene file. Export the scene. Run the Cloud client app and load the scene.
Second option: I suggest you try a render mask with the Objects property. You can find the option in Render Settings → V-Ray Tab → image Sampler → Render Mask Objects.
Cheers,
Nice one, thanks for the workaround Boyan!
