C4D VRayNoiseTex
What happened to the VRayNoiseTex?
I can’t find it anymore : (
Hello @Rickmc
VRayNoiseTex is a texture for noise in V-Ray for 3Ds Max.
Are you referring to VRayNoiseMax texture? Please, be aware that the texture is currently unavailable. However, it can be used with V-Ray Node Materials.
Would you let us know why do you want to use this specific texture and not the Cinema 4D’s Noise texture?
Sorry, I was wrong, I mean the Noise Shader, not Cinema´s Noise
Hello @Rickmc
As mentioned above the VRayNoiseMax is currently unavailable. Instead you can use the Cinema 4D’s Noise texture: http://ftp.chaosgroup.com/support/screenshots/Cinema\_4D\_2023-06-14\_12-04-42.jpg
Please be aware that the VRayNoiseMax Node texture is available for use.
If this does not answer you question, please give us more details regarding the feature you are looking for. A visual representation would be useful as well as the version of the V-Ray you are using.
I miss this guy:
Hello @Rickmc
Thank you for clarifying. As mentioned above, the VRayNoiseMax texture is currently unavailable. However, it can be used with V-Ray Node Materials.
You can use the Cinema 4D’s Noise texture instead: http://ftp.chaosgroup.com/support/screenshots/Cinema\_4D\_2023-06-14\_12-04-42.jpg
Sadly, VRayNoiseMax was better than first expected.
If I get it over the Node system, ok :slight_smile:
