Cache location for DR jobs?
Where is the cache located for DR jobs sent to BB? I suspect I have old jobs in there that remain even after clearing out the Queue Monitor. I’m running out of space on my OS drive and would like to check.
Thanks.
For Distributed rendering the assets are stored in the default system temp folder, usually C:\Users\<username>\AppData\Local\Temp on Windows (%TEMP%), is used for copying the assets if the VRAY_ASSETS_CACHE_PATH environment variable is not set.
Backburner itself stores files in %localappdata%\backburner\temp
You can use a 3rd party software to scan your hard drive and see what’s taking so much space - TreeSize, for example, has a free version.
