Cache Previewer Minor Request
It would be way cool if there was a button in the Previewer to let you copy the cache filename (ideally one to copy the filename, and one to copy the entire path-- or alt-click to copy the entire path or whatever-- the path is actually more important than the filename because it can be pasted into a node to load it in.).
Thanks.
Yess, sounds like a 10 minute thing and there also are a couple more things I need to change in the previewer while I’m in the area…
You’re the best.
Aaaaand it will be in tomorrow’s nightlies :slight_smile:
Awesome! Thanks.
