a recent project i worked on , didnt have much time on it but i liked the way it turned out .
would appreciate to know ur Comments
Lighting seems fine - good and sunny. But that DOF, thats way ooooff imo.
yep - looks like a tiny weeny mini model to me. If that is what you aimed for, well done.
DOF was done in post , i cracked up the blurring to hide many inperfection & to just show a certain area .
had alot of problem with trees & vegetation they were not looking real , so blurring them worked for me ![]()
DOF is off but I like the effect. Lighting looks great.
Use VRay DOF as a guild
Regarding the DOF [that is unrealistic & making everything look miniature]
I understand that a lot of people want to use DOF as a post effect but by doing this you have no way of knowing if it is realistic or not.
As a guild you can use a low res & low sample/quality render using VRay Physcam so you know how much DOF you should have.
With a wide angle lens over the distance you are using, you wouldn’t get much DOF at all. Heavy DOF only occurs with a narrow FOV, extremely low F-stops or close-ups.
As the Physcam DOF is physically correct I would always suggest using it as a guild even if it’s not in the final render.
Hope this helps
Jamie
unless you are on a large format camera, where a normal or even a wide angle at f22 still doesn’t have everything in focus ![]()
Buck
Thanks for the extra info as my knowledge of cameras is limited to certain basics. I had a look at your photography site & you certainly know your stuff…great photos!
How would you set up VRay Physcam to replicate a large format camera??? [is it the Film Gate??]
& will VRay physcam give the same results if setup this way???
Also is there any way to know how much distortion there is with different lens sizes. [Such as a really wide angle or fish-eye style]?? I have always noticed the large distortion/bending in fish-eye lenses …but how to know what value the distortion of VRay physcam should have???
Thanks for your time
Cheers
Jamie
yea, to replicate the DOF of a large format camera, you could put in a much larger film gate. 36mm is the width of the film, so for a large format, you would put in something like 250mm for an 8x10 camera. Not sure how Vray would handle that though, but in theory it should work
And then for a “normal” focal length (like 50mm on a standard 35mm camera) you would use somewhere around a 360mm focal length.
Just as an aside daniel - the mustang garage flash shots look great!
