I present this image render crown.
PT + HD
HDRI Lighting
Render time: 2 hours
Pts: 80 msi: 800
you need to work on the ceiling and the fans
the glass looks great ( as always with corona
) and the brick wall is nice too maybe try to make brick up and down in the geometry and then put a map on them make them a lot more realistic and genuine . you can try using multitexture map from cg-source it is free i donno if it is supported but you can always convert it using dead clowns converter
some burning on the wall from where the light is coming
what i likes most was the sofa ![]()
but the contact of the geometry and the floor was not present :c
Multitexture is not supported by the converter - so it will not be converted. I don’t know if it’s already stable in daily builds but I’m pretty sure it’s not working in A5.
[/quote]
oh got it
thanks as always for your kindness and generosity for his great insights, I will continue improving the image with advice. ![]()
looks good to me ![]()
maybe others can provide more insight ![]()
