since I use one camera and animation to change it’s view will I be able to change resolution for each frame? This would help so much since I just put a batch of views to render consecutively.
Hi, thanks for posting. I will check with the devs if this is technically possible. Highly likely it is not though.
At this stage, we are focused on stabilizing the existing camera override resolution process in general and unfortunately do not plan to implement animation.
Anna
