Hi
I have interesting bug in DR and i haven’t found a thread about this.
I’m using camera animation to render series of images (20+ houses in neighborhood). First frame rendered correctly, but second one started ok on my main PC, but when new data arrived from slave it was from previous frame. It looks like slave stuck on frame 0 while master is rendering frame 1. In result i have image with two frames blended together.
This exact bug was reproduced by my friend in other scene in her office.
Is there workaround to fix this, or do i have to change my method to multi-cam and batch rendering?
Thanks for your answer. I was thinking about splitting task among two computers, and for now this is my only way to automate process. Sadly, right now I don’t have time for troubleshooting, but I will look into this problem closely soon. Maybe it’s something with 3dsmax.
I might be not clear enough, English is not my first language. I have been using animated camera, and this caused a problem with slave. I’m going to try few things, and if this doesn’t help, I’m going to split my frames between 2 computers without DR. Or i would have to finally, after 7 years, learn backburner
I’ve been animating my camera to render a sequence of images. I don’t use batch (i didn’t even know that’s not working and it’s hard to implement). My last sentence from first post was unnecessary.
It might be one time problem then. I’ve rendered few frames “manually”, then started another sequence, and now it’s fine. I like working with corona, but i’m keep forgetting it’s still alpha.
