Camera animation don't work
I export vray scene from 3ds max.
The object animation is ok, but camera animation don,t work.
after some test camera animation, this work only if I export just one camera and only if I select the camera before.
Depth of field animation don’t work.
If you open the animation editor in Vantage, you can right click on the scene track to select the .vrscene camera to be used for animation playback.
See attached screen-shot.
Which parameter are you animating ? Can you give us a small example scene ?
Animating the enabled state of “depth of field” won’t work, but other parameters affecting the DOF should work as animated.
Greetings,
Vladimir Nedev
Thanks for the prompt reply. Now I view all cameras.
I noticed that animating the Depth with standard camera, this doesn’t work, but if animating with vray camera the focal point, then it works.
Looks like an issue in the .vrscene exporter in 3dsMax specific to the Standard camera.
Not a high priority issue, since you are supposed to use the Physical/V-Ray Physical Camera anyway.
Greetings,
Vladimir Nedev
