I noticed this happening a few times. Usually buildings are set in a model based on geolocation. So they might get far away from origin and they might have to stay there.
Thanks,
Bogdan
Hi Bogdan!
Looks like a bug. Could you please send us a feed back and provide an example scene to our support?
Or if it is easy to reproduce, line out the steps to do it here ![]()
The problem appears for small scene too. For example if someone try to render a small product like a jewelry ring. The near clipping plane clips the ring. Maybe there could be added a solution too.
@Micha , could you kindly briefly send me an example project in which I can reproduce this problem?
Hereās a screenshot with a file
camera clip3dm.jpg is actually a 3dm rhino6 file. i renamed the extension because i donāt know how to upload files on this forum
Aha, now I see that zip is allowed as an attachment ![]()
Thank you both for your cooperation! Weāll check it out and get back to you with news as soon as possible. ![]()
@Micha , this behavior is by design, weāll look into ways to improve this behavior in the future though. Further, @FloatingVolume , what you shared is actually an issue, so we filed a bug report for this weāll look into resolving this as soon as possible! ![]()
Thank you both for the feedback and cooperation.
hi to everyone,
I post here because i had similar issues, iām working with Rhino 6.
My model is close to the origin .
Enscape works well when the camera is far from the objects (see capture01) but as soon as i try to get closer, my objects are ācutā(see capture02).
My goal there is to produce interior rendering of the space , when i try to synchronise the view from rhino to Enscape, it is not showing anything (see capture03). we also tried to manipulate the view directly via Enscape, it didnāt work either.
Iāve tried multiple settings (camera settings in rhino, general setting of enscapeā¦) and found nothing to solve this issue.
Do you people know something that could solve this problem ? Or maybe know where does the problem is coming from ( camera setting ⦠)?
Hoping iām posting this in the right topic,
regards,
Baptiste
Is your model in the right scale?
Iām also having a similar issue. Iām doing an animation where I zoom from a person next to a building to a flyover of a master plan. As the camera zooms out though, the further it gets from the buildings, it begins to clip them out of view.
If I look at the specific keyframe though, everything is visible. It only happens when in the animation.
Model is right scale.
@baptiste_1 - that looks possibly like an origin issue (-37216, -896 in your screenshot)
@ashtonstare - could be you are having the same issue? Can you check your origins please?
This is still happening. When the model is far away from the origin, and template is large objects millimeters.
@FloatingVolume - if your using a template set to millimeters, your geometry will be scaled small, and we set the clipping plane where the assumption is that 1.0 equals one meter. Try scaling up your objects and you should find that the clipping issue is resolved.
If scaled correctly, clipping will then only happen where objects that are far away from the origin may then have problems with floating point precision, meaning geometry representation precision is affected. As soon as that precision is not enough, then geometry is not represented correctly. Thatās when clipping would likely occur.
All our buildings are drawn in mm and sometimes set far away from origin to match the cadasters.
@FloatingVolume - if the projects are set away from the origin then precision issues start to occur in Enscape, and the scaling issue I have already explained.
I can only file a feature request for this, as you have also provided a Use Case, then that may help. I am not sure how much of this is a technical limitation, however, and perhaps one of the developers here will chime in to provide some more background information as to why or why not this may be something that can be addressed.
I found the same issue when I began modeling and rendering in Enscape. The live Enscape view became jagged, slow, and extremely glitchy when modeling something about 2-million feet from the model origin. For a landscape architecture firm it is important that we keep our models true to the original coordinate system (and one of the many reasons I prefer Rhino over Sketchup) so that we can export models back to CAD for construction documents. So it would be nice if Enscape could resolve this precision issue that Pete mentioned.
My workaround has been to have two Rhino files. One for Rhino modeling and another one for Enscape modeling and rendering. The āEnscapeā model has the original Rhino file as a linked block so I can still make updates via the BlockManager. In the Enscape model, I then move the linked block to the origin which fixes the Enscape performance. In the Enscape model, I then add all of my assets, plants, video paths, lights, etc. to add detail to the scene. It definitely adds time to my workflow to save and update between two files but works for now.
Iām not a software engineer, but is it possible for Enscape to render based on the active construction plane instead of the world construction plane? Iād be ok with switching construction planes to render as opposed to my aforementioned workaround.
@aharrell - I have added a feature request in regards to the use of the active construction plane as opposed to the the world construction plane when rendering with Rhino.
Thanks for offering up the workaround as well though, perhaps it will help some other users circumvent this current limitation.
