Hi
When using camera clipping “show in viewport”, the line has a limit where we can see it, if I zoom more to put it exactly where I want I cannot see it, is there a value where we can change in viewport config to always display it?
Reproduced and logged, thank you!
(Report ID=CMAX-1814)
I’ve found that it deppends of “Target Distance”, larger values shows the clipping lane no matter the zoom, this had helped me, but hopely you could improve it, thanks.
According to our investigation, this is unfortunately a 3ds Max issue.
Thanks Maru.
Activating Camera target shows the clipping correctly, im used to turn it off but with this limitation, its not really bad to leave it on.
