Camera Feature for VrayDecal
Dear Chaos,
I have a big 3D ground setup [consisting of 3300 tiling vrayproxy’s [and 3300 materials] ].
I’m using a VrayDecal to project a parking lot [Is a test for now], which is working just fine.
Downside is it’s difficult to make an EXACT match with the ground textures, especially the scale.
It would be nice to render the EXACT projection of the decal to be used in Photoshop to make the Decal texture.
So, Is it possible to get an camera option in the viewport to see the decal projection .
As already available for lights,…
see attachment
Hi, thanks for posting.
Could you explain a bit further? You are rendering a projection of a terrain with Decal and later you are adding the parking in photoshop. Is this correct?
As already available for lights,…​
If you need to look through the Decal you could align a camera to it.
Hi Vladimir,
Yes, Im rendering the projection and then adding the parking lot in Photoshop.
Yes I know but there’s gonna be a lot of camera’s [and parking lots, and so forth] in this scene,.. so I kinda dont wanna make extra camera’s for this…[if it was one or two I wouldn’t even post this]
tnx for the quick reply!
greetz Chris
It is much better to have assigned cameras than switching viewports.
If you have to edit the project after a long period has passed and you don’t have cameras with proper names this could be a challenge.
We discussed your idea with the teams and for now we won’t be developing such a feature.
I hope you understand and that does not discourages you to share ideas about improvements to V-Ray.
Thanks again.
