Camera in Photographic Exposure mode
HI all, I’m just opening new RC 8.
What happened to Photographic Exposure mode in camera parameters? Was it removed?
I found a flag/parameter to add for the Tone Mapping, but seems to work as a “filter” over the image and not as the previous photographic exposure.
It seems to work correctly only if Advanced Filmic Mapping is turned off.
Let me know. Using the camera as a real camera is fundamental in my process, is not a really comfortable solution right now.
Having just the flag was pretty straight away before.
I would also like to know what is happening here.
Have you tried using the c4d camera photographic values?
I know for depth of field at least corona is using the fstop from the default camera parameters, not from anywhere in the tag.
Corona Frame buffer, Tone Mapping options, + add photographic exposure, now you can play with iso, f stops and shutter speed
It’s still there, just moved :wink:
