camera inactive
Hello tout le monde,
I use cinema 4d 2024.1 and coona 12.
When I create a camera, I change its parameters no matter how much, nothing changes.
Is there any special handling to do?? I’m a beginner on this rendering engine. Excuse my English
Are you familiar with C4D ?
  • check if the camera is really in use in the viewport ( white square with a dot at center in the object manager )
  • for each group of settings specific to the Corona Camera you have to toggle Override and Enable ( override to bypass the settings and values initially located in the Render Settings, then Enable to use the effect ).
