I have a photo taken with a camera with a 36 mm film gate and a focal length of 24 mm. (Canon 5D Mark II)
The photo however is taken with the camera rotaded 90 degrees.
How do I translate this into a new film gate and focal length in the V-Ray Camera?
I’m guessing 24 mm film gate, but what about the focal length?
I dont see why it should make any difference that the camera was rotated 90 degrees. If you then went and rotated the resulting jpg, then just render portrait instead of landscape with the same film gate and fov you would use when the camera wasnt rotated 90?
I think with a standard max camera you can switch between horizontal fov and vertical fov. According to a table here: http://en.wikipedia.org/wiki/Angle\_of\_view a 24mm lens has a horizontal fov of 73.7 and a vertical fov of 53.1 so maybe try typing in 53.1 into the vrayphysicalcamera fov? (fov of 53.1 equates to 36mm…)
I just did a camera match like this and it turned out well (with a 24mm lens too)
This work fine if you keep the frame aspect landscape (i.e. your render is landscape). However, it looks sideways in the viewport…
If you make the frame aspect portrait then your film gate and focal length (and even FOV) will change because VRay uses the horizontal film gate and horizontal FOV.
Multiply your focal length by the image aspect in the render dialog (after you make it vertical).
So if your film gate was 24mm high x 35mm wide for landscape and you were rendering to 2400px high by 3600px wide…
then duplicate your camera.
Make the new camera have a 24mm film gate
then change the frame size in the render dialog to 2400 wide by 3600 tall
Read the Image Aspect (0.66666 in this case).
Multiply the focal length by this number. Now you should have the same horizontal FOV.
Note that for it to be like a real camera, though just setting the frame size portrait and setting the gate size to 24mm (or whatever the vertical gate size WAS) works.
A real camera does not change the magnification/FOV when you rotate it.
Thanks for the answers, I didn’t get to try this since the client changed to another photo which was landscape.
I will try a standard Max camera next time.
Here’s a quick demonstration of the correct way to have a portrait camera and an incorrect, spot the difference, and compare with the landscape camera to see why it’s correct. I unfortunately can’t share the powerful script we have for doing this properly, but it’s pretty simple math.
