Camera Matching
I’ve been trying to figure out camera matching (simply for stills at the moment) but am pretty lost.
I followed a tutorial that I found on Evermotion and read the Max help files but I didn’t get proper results. Attached is the closest I could get in an interior room. Any ideas what I’m doing wrong?
Hard to say with out the file but normally it means one of the markers is off, do you have good measurements? The Max Camera matching system is really old and crap and needs good markers.
looks like too small fov to me. If you have room dimension right i’d say try the cam matching tool.
Regards,
Thorsten
Thanks guys but no I don’t have any dimensions… I’m assuming they are needed?
For stills I’ve had pretty good results using sketchup, pretty much have to just guess at the scale if you do not have any measurements, ceilings hgts are a good place to start guessing…
Ah thanks.
