Camera move faster
Hello. in the shortcut list, I didn’t know how this common works? or why this is gray and disabled?
Hi yones,
Shortcuts which are greyed out cannot edited, only white shortcuts can be edited and reassigned by using LMB click on the shortcut or RMB click > Edit. Additional options for shortcuts are Delete, which removes the shortcut and Reset, which restores it to default value. In this case [Shift+] means that when you navigate with WASD(eitherin Free look mode or while pressing the RMB+WASD) and you press Shift your camera speed will be increased x2. The Move speed can be set from the Camera tab in the Navigation group.
Alexander
