Is there a solution to move around without press mouse1 bottom?
Is very annoying. Should be like in video games to move only the mouse around.
@alex1986 , thanks a lot for your request - It may take a bit to get used to the alternative controls of Enscape coming from first-person games. After a while, you should not notice it as a problem anymore and this current implementation allows for quick access of any Enscape Settings / Commands. Alternatively, you may also want to perhaps use an Xbox controller which allows you to look around using the joystick directly, just in case this may be of interest.
Otherwise, let me know and I will also gladly file your feedback as a dedicated feature request which can then be discussed by our developers.
Thanks in advance!
