I’m trying to improve the camera path settings, but the path is invisible to me.
How can I toggle it on and manipulate the individual camera positions and path segments manually?
The animation stutters and I encounter jump glitches, I hope to improve it that way.
Welcome to our forum @Starsailor78 !
When you open up the Video Editor, then add some keyframes however you like, you should be able to turn around and see the path accordingly. I am not sure why it’s invisible on your machine, it should only be invisible if you close the video editor again. Maybe please make sure that the Video Editor is still activated and then you should see the path accordingly.
I hope this helps already, please also let me know if you’re not successful with resolving the stutters and jump glitches then.
