Camera Path
So we use Rhino and Vray and often need to create an animation to show the client the interior space. Typically doing a fly through or walkthrough the given space
Our only go to at the moment is Enscape or Lumion. Lumion if we need moving people and/or textures or Enscape if it doesnt.
We want to use Envision to keep the workflow easy as we can use vrscene files, however i still struggle to understand how to make a fly through or walkthrough. The way Enscape uses a camera path and its smooth transitions as you look around the space is very powerful. Can this be achieved in Envision?
Ive looked at a camera following a spline but it can be hard to predict the speed of the camera and its very speedy /choppy around corners. You can also only look at one object along the path. Is there a way to create Enscape style animations using paths? (_ basically just look around and add keyframes and its super smooth).
We look forward to your comments
Cheers
In addition to the move on spline and look at constraints, the camera track has auto-recording translation keyframes, so you can define a specific position/direction for every point in the timeline.
Does this work for you?
