Listing bugs that we are experiencing from the 1.5.6 version still:
- Doesn’t export Automatic Vertical Tilt Correction for Vray camera
- Sometimes does not export the correct resolution/aspect ratio
- Doesn’t export cameras that are set in the 3ds Max viewport tab
- Sorting by name/date/etc. is not available when setting in the Animation Editor through right-click > Active Camera > list of cameras
- Can’t select multiple cameras in Camera Lister to delete/move to a folder
Submitted on AHA Ideas (VANTAGE-I-329).
Vertical tilt is exported as baked option in the Tilt and Shift options and this is an export task that V-Ray will have to implement if you need to be a toggle. The same goes for the incorrect resolution/aspect and the viewport cameras. The camera that is set in the viewport is the Original camera in the Camera lister in Vantage. Also the exposure of the VRayCamera exports and it is supported in Vantage. Can you please send us a video and/or a scene to https://support.chaos.com/hc/en-us/requests/new so we can check what is going on. For the UX improvements for multiple camera selections and drag to a group and the active camera they are logged in our internal system.
Submitted on AHA Ideas.
AHA Ideas status: New.
Set during AHA Ideas to Discourse migration.
