Hi;
Is there a way or tool that anyone knows of that allows me to link a certain frame-nr° to a camera to render?
Pulze scene manager allows this, but only for animations, meaning 1+ frames, which is very annoying. Can’t use it for single frames
Grts
edit: .net render in Batch rendering UI - solved.
What’s your goal here? You can use batch render to setup multiple camera’s with custom frame per camera. And there’s a good batchCam renderscript on scriptspot.
In the updated version of Scene Manger there will be a Time Output card. It will solve your problem. It will be available in the same time as the new Render Manager.
