So I usually set standard cameras in 3DS max with Camera correction modifier. And then I use Live-link to and select (and view through) in 3ds max camera and click on ‘Create new camera’ in Vantage. After a while the cameras in vantage loose their camera correction I suppose and I have to repeat the process again. I suppose this is due to the clash between ‘Vertical tilt correction’ in Vantage and 'Camera correction Modifier ’ . I there a solution for this?
Have in mind that in Vantage you are always modifying the “current” camera, which isn’t linked to any of the saved camera slots.
If you want the changes saved (whether they are coming from the live link or from modifications in Vantage), you have to click the Save button next to that camera slot.
Greetings,
Vladimir Nedev
