I understand that you can not handle multiple DomeLights even with V-RayNextUpd 1.1.
But can animate the On / Off switch of V-RayLight (Dome)?
I want to switch the effective dome light during animation.
maybe try changing the multiplier to 0
if you are using it with a map in, you could use a mix map in the domelight, and keyframe the mix from one map to the other over 1 frame. that way youd only need 1 domelight.
thank you for the advice.
The solution seems to be to animate Map.
