Are there plans to add this feature?
Hello @123456_1 I have shared your idea with the team and it’s up to a discussion. Thank you!
It will be very useful if you could give us some additional information on the scenarios in which you will find this useful.
For example, metal in an indoor environment may not reflect its surroundings very well. In this case, I can add an environment as the reflection source for the metal. This feature exists in C4D’s Corona and in 3ds Max’s Vray, so it is still quite useful. ![A)0[quote=“viktor_angelov, post:3, topic:118888, username:viktor_angelov”]
[/quote]
For example, metal in an indoor environment may not reflect its surroundings very well. In this case, I can add an environment as the reflection source for the metal. This feature exists in C4D’s Corona and in 3ds Max’s Vray, so it is still quite useful. B(F_E~IRB%$DA@JD[XW.png|669x549](upload://hWBaMNt5ec1wk9Jn28RGZzr4k4h.png)
Thank you @123456_1 I have shared your feedback with the team and we will be discussing this internally.
