can corona scatter get color from surface?
Hello, Can Corona scatter get color from surface?
moderator’s note: removed spam link.
Officially no, but you can use some workarounds and try to achieve desired result: https://forum.corona-renderer.com/ abstract boxes in corona render
Hi, there is no direct feature for that in Corona Scatter. But we work on an improvement w.r.t. that.
Hi, you can check out the new Chaos Scatter that has been just added to the [latest Corona 8 daily build](https://forum.corona-renderer.com/ Corona Renderer 8 for 3ds Max - Daily Builds Changelog #msg192647). It should be able to do that now - there is new Surface Color map under Chaos section in SME for that.
Yes it can with new Daily Build Corona Scatter:)
My test in attachement.
Szymon
Is this possible in Cinema 4D? Because I cant find the Surface Color shader here.
Hi there ShynnSup,
The dev team is working hard to include this feature in Corona for Cinema 4D.
You can keep track of the features that will be included in future versions by visiting our roadmap here: https://trello.com/b/dgI8vjDb/corona-tentative-road-map-cinema-4d
I hope this helps.
Have a lovely day/evening.
