Can Enscape 2.3 and 2.4 coexist on PC?
Hi! Is necessary unistall older version and then install 2.4? is it possible to have on pc enscape 2.3 (work) and 2.4 for test?
No, you can not have two versions installed at the same time. But you can downgrade again by using the v2.3 installer if you like - but it’s not recommended since we fixed so many bugs and improved things since v2.3.
