I rendered a scene with GPU and CPU. On the left you see GPU - the texture is blurry and flat. The original texture-PNG is 4096x4096 Pixel. Is it possible to get the same nice detailed result with GPU?
In the renderengine “full size textures” is activated.
So it is down to how GPU handles texture filtering vs CPU.
Is it bump map? normal map? VRayBitmap? are you using VRayColor2Bump? tex filtering type used on CPU?
Just increasing the bump value might be a quick fix.
edit: I’ve just noticed this is C4D, there might be some other issues at play (I’m on max)
As @piotrus3333 mentioned above, the issue could be related to the bump map. Currently, there is a known issue where rendering bump maps on CPU and GPU are not identical. Would you mind sharing a simplified scene (with all assets for it) where the issue is observed so we can have a look and confirm if that is causing the differences? Thanks.
I think you are right. I rendered with CPU without bump and it looks very similar to the GPU-rendering. So what can I do to activate the bump with GPU?
Please note that the attached scene didn’t include any textures so I couldn’t test it.
With that being said, please note that there is a known bug where bump maps on the CPU and GPU are not identical. The bug has already been reported to our developers for fixing (bug ID: VC4D-1312) and I will let you know once we have more information on the matter.
As a workaround, you can invert the bump map using the invert option in the V-Ray Bitmap, however, this has to be done for each texture separately.
Please note that there are some known differences in the normal maps when comparing V-Ray and V-Ray GPU. We will be working on improving this but I cannot provide any specific timeframe. Thank you.
But is there any possibility to use the normalmap with GPU? I wrote you about the problem that your workflow didn’t work. In my case the differences in rendertimes are huge.
I understand your frustration. However, this is a bug that needs to be fixed but I cannot provide any specific timeframe for when this will happen. I will let you know as soon as we have any updates on the matter. Your understanding and patience are highly appreciated.
As you might have already seen in the Announcements section, we just released V-Ray 6 for Cinema4D, Update 2. With it, we introduced many new features and improvements, along with numerous bug fixes. Please note that the bug with inverted Bump maps with V-Ray GPU, discussed above has now been fixed. You can download the latest builds from here. I hope you will enjoy the new features!
