can i know why the light reflection is not consistent
i would want to ask why the reflection of the red clouded portion is blurry and not the same as the other? does this mean its about the hardware lssue? or the setting of the reflective properties of the black granite flooring? (please refer on the attached image with a red cloud portion)
can somebody enlighten with this and thank you in advance
Would probably need to see the scene as would need to know the materials, the geometry, and other values in the scene set up (such as DOF). You can always send it in via ticket at Chaos.
If you don’t want to do that, the only other way would be wiregrabs, screengrabs of all materials involved, of render settings, and of camera settings, which would be a lot of work for you :smiley:
we will need to investigate your scene to understand the issue. Please use the link shared by Tom above to start a ticket with us.
Hi, what you are seeing here is the UHD Cache solution. You should not be seeing that. :smiley:
It sometimes happens when effects like glossy reflection/refraction or translucency are at play.
To fix that, you can try going to Render Setup > Performance > UHD Cache and:
  • changing preset to “animation (flicker-free)”
  • and/or changing precision to a higher value (I would advise trying with 2 first, and if that doesn’t help, slowly increasing it further and checking the result)
