Here’s the case:
I need to render a hi-res still image (4500 pixel long), and i want to render it via backburner using the split-scanline / striped render or whatever it’s called.
I’ve no problem with network rendering, i’ve done it for years. But, I can’t figure out how to render separate reflection pass this way (or any other of the render elements). Is it do-able?
I’m not sure if Render Elements are supported for striped rendering, but I suppose you can give it a try. Just remember to use the 3dsmax VFB and not the V-Ray one. If striped rendering of render elements works with the scanline renderer, it should work with V-Ray too.
Ouch, I didn’t realize that it’s not a vray problem, but a 3dsmax issue:) Pardon me
Anyway, i’ve tried rendering render element with striped rendering (3dsmax FB, no VFB). It seems that 3dsmax did render the elements fine
BUT
the backburner didn’t sequentially named the element stripes. So, it saves each stripes in one file, over and over again. And in the end, i just got one element stripe (the last one rendered).
Of course, i can ‘rename’ each stripes right after they finished rendering and later stitched 'em manually, but that’s just not a solution :).
That happened to me also some days ago.. I found it the hard way. Anyway, it would be nice to have this working on future versions… with DR+backburner also ![]()
Render elements work fine with DR. In the newest versions DR works fine through backburner too.
Vlado, what about my question. Is there a solution http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17497
