You can set environment textures through the SettingsEnvironment plugin. Check the comments in examples/cpp/settings/05-environment. The example only uses flat colors, but you can use images of course. The environment in V-Ray terms is the sphere that surrounds your scene in all directions. So usually spherical or cubic environment maps are used. If you want to use a flat 2d image as a background, you should use the “screen” mapping type for UVWGenEnvironment. This should be used only for the bg_tex slot and not for GI or reflections as it will not cover the scene from other directions.
p.s. The image on the right uses a ground plane that catches the shadows - this is what the camera sees directly and not the environment. The image on the left has no ground plane, so you see the color of the dome light above and black below it as there is no ground object or environment color.
You can use the GeomPlane plugin instead of GeomStaticMesh for the plane. GeomPlane has no parameters. You just set it as the ‘geometry’ input for a Node.
I really recommend looking at the vrscene file of the scene in question for more details. Notice that there are many settings plugins in every vrscene file with many properties, but they are often the default values. V-Ray just always writes them. So it’s best to compare to your scene (exported to vrscene file as well) and only add code that sets parameters that have non-default values. The C++ code for creating plugins and setting parameter values is similar for everything. Only the names of the plugin classes and the names of the parameters are different.
