Hello!
I’m trying to design some different building in front of the cloudy sky, but I found can’t make the sky(cloud) look the same,
Can i save the setting of Enscape like “Photoshop effects” that I can apply to each different file?
Any ideas or suggestions are greatly appreciated.
Welcome to our forum and thanks for your inquiry!
The time of day itself can be saved through scenes, settings themselves can also be saved either into the current SketchUp project itself, or as separate settings files independent from the project. Check out this article here for further information:
https://enscape3d.com/community/blog/knowledgebase/link_view_to_preset/
Let me know in case there is anything else I can help you with!
… which is a “strange thing”
Since I usually always develop different design variants for a project - all saved as separate SKP files - I use the same preset file for all variants. I say “strange”, because I never manage to make the sky look identical although I only use this one preset file …
Have you made sure that the time of day is identical as well?
