hello. there is a bug I think in the new render dialogue. when I change from sequence to still, I can not change the mp4 format to png.
If you go back in to the sequence tab and change the output type back to image, then it will allow it.
An oversight I think, to have the option linked like that…but an easy fix ![]()
yes, that’s a solution but I delete my animation and can not back to the sequence. this is gray and disable ![]()
I tried also deleting the mp4 but it is still possible to change to image, so maybe you have a different problem or missed something.
You should post screens of both dialogue boxes, the image one and the sequence one…maybe someone can spot something ![]()
Thanks for reporting this. It will be fixed in 1.6.1.
