Hello.
I´ve downloaded Chaos Player to try out, but it doesn´t recognize my license server.
Tried to move the license to local and the same window pops up.
See if changing the license settings from here helps: “C:\Program Files\Chaos Group\Chaos Player\bin\setvrlservice.exe” (or look for Change Chaos Player license settings in the start menu).
Doesn’t it help if you enter a valid IP:port on the window in your screenshot?
Do the rest of your Chaos products keep working (i.e. they find the correct license settings)?
Yes, everything is working with other products. IP addresses are correct.
Can you make sure that your licensing account has a Chaos Player license?
The easiest way to do it is from the license server’s interface (locahost:30304)?
I don´t because i´ve download as a tryout, and not a full license.
It seems you don’t have a license on your account. Even trials add a temporary license to your account, so some step definitely didn’t go right.
It would be best to contact our support team following this link: https://support.chaos.com/hc/en-us/requests/new and they’ll help you sort this out.
Tks, but not worth it right now
