hi,
i have a reduced to the min scene here. maxdesign2015sp2/vray 3-10-03
i woul´d like to know where the splotches at the ceiling come from ( max region) .
no lights in scene, 2 materials.
you can´t see them at 1600 pixel, but at 4960 they come along.
irrmap subdivisions at 100, interpol samples at 40.clamp output set to1.
they should not be there …i´m lost, i have no further idea.
Try using the light cache as a secondary GI engine, and also add a bit of offset to the texture to avoid having pure black colors - try setting the “RGB offset” parameter in the Output section of the map to 0.1, for example.
If the issue still persist please reattach the zip file again (“splotches.zip” seems to be invalid) so we could have a look at the scene.
Or send it to: support@chaosgroup.com
The Irr. map Color and Noise threshold are quite high in this setup. You can try to lower them both to 0,1 for an example.
…also if i want to edit my post, i can´t see any text in the text field. it´s empty ???
It happened for me a few times and the solution was to Logout > Login.
