So in short, the Vfb does automatically now save all exr files as scanline, not bucket?
I agree the autocrop info will make a big different, but will it skip the alpha pixels, or all unused in each element, as the later would be very cool!! I am not sure that will be the case tho.
I think Vlado needs to give us some clarity on this situation, as my head hurts.
EDIT: Just tests also, the MaxFB has made a .exr with vray RE and with autocrop, and scanline. Lovely, but it took 33 seconds, where the Vfb took 22. Not so good on a larger scale!!.
More info, the maxFB will render in 22/23 seconds only if the RE are turned off. So the 10 or so seconds slowdown might be the same on an hour frame - only 10 sens difference. More testing needed, but I think from this you could conclude that the Vfb should be off for the final render, and use the maxFB instead.
Yep - the autocrop is based off the alpha channel of the image so it’ll draw a box around the alpha channel and skip all of the black pixel areas. If your elements have less information again it still uses the alpha for it’s crop, but it’s a damn sight faster than non crop exrs.
If you go out via the max file save dialog and load in your render elements in it’s exr options you’ll get it. I haven’t had a proper test but I think it might fuck up vray velocity and depth though?
Working perfectly over here Vlado, this’ll come in really handy. On Game of thrones we were getting 130 meg EXR files which were really nasty to use directly in Nuke, but the VRIMG to EXR process naturally added it’s own delays too. This is going to come in really handy - I really like the new MTL reflection glossiness element too - we’ve a lot of options for chasing down noise now!
