Can you do a Global Reset to all VRay Settings?
I’m having an issue with my main workstation rendering differently than the DR machines. Currently, it looks as though it is receiving a different GI lighting calculation that the other nodes. And I’m positive that is not the case. I believe I’ve narrowed it down to the point when I tried doing the Linear Method. I thought I reset everything and it started getting closer to matching, but still isn’t 100% there.
Is there a way to reset everything to the defaults of VRay as if it was just installed, or is the Linear Method set up through Max, and a reinstall would have to be done?
Thanks!
AFAIK, you can reset all of Vray’s settings by changing the default renderer back to scanline and back again to Vray.
