Can you export to Adobe Illustrator?
Hey all,
For today’s conundrum, my manager has asked if I can export my renders to an appropriate file that will work as a vector in Adobe Illustrator.
As far as I know I would just do a normal render and then image trace in Illustrator but I thought it best to ask you experts just in case there is something more direct?
I’m using Vray Toon shaders and the outlines. Is there something I can do directly or maybe a plugin that lets me output SVGs? I tried an EPS files and it just imports into Illustrator as raw code.
Thanks!
I doubt there would be a way of converting a render to vector in V-ray or Max.
There are some websites that will “convert” raster images to vector. I don’t remember which ones off hand, but I’ve used them before with decent results.
this one can do that
“It currently supports Shockwave Flash, Adobe Illustrator, and Autocad DXF output”
there is a 30 days demo for testing to confirm if it will works for you .
Thanks, I was aware of this method but from what I can see, it won’t be the same sort of look as I get from Vray. Kinda want to keep the reflections on the model instead of being purely flat. I’ll give the demo a go though and see what I can get out of it.
