As jconnell points out Max Ray Intensity comes in handy for this. If that will not solve it you can also clamp in the color mapping, but clamp to a value of 3-5. This usually gets rid of the bright highlights issue (the ones that slow the render and can flicker), while still maintaining enough superbright values for most uses. You would do this in conjunction with Sub-Pixel sampling. Yes, this is not as accurate in terms of how the light will bleed out around edges, etc. but is sometimes needed to get sane render times.
