I am having issues canceling renderings. GPU or CPU, both will not cancel, or stop, on several different scenes.
Does the issue occur in a specific scene?
No, and not all the time. This happened before in previous releases, and stopped for awhile, but it seems to be back.
As always lots of information to go on. Always fun the play the guessing game.
Is this in the middle of a render? During the geometry calculation fase? During lightcache? Using progressive / bucket / … Do you have lots of displacement? Which type of displacement (2D/3D). Lots of scattering very high poly objects (using FP or Chaos Scatter)…? You know, hard to be helpful if there’s no information provided.
There is no rhyme or reason. I have 10 houses, all with interiors and all built the same with the same assets. Most render fine, and when I can’t cancel a render, it is random. I go back to the scene it’ll render and cancel fine. It can be rendering for an hour, and I can’t cancel or stop it.
are you using almost all of your memory? sometimes when a machine’s memory gets full, funky stuff can happen.
Good point, I’ll keep an eye on it.
