candlelight* Updated with Panda page2
jsut want to share this candle light using refraction and emmissive materials
Re: candlelight
that light looks very real nomer, the wax need little more work, but the light is perfect, cheers.
Re: candlelight
Hi sir nice out put, cant wait the tricks :stuck_out_tongue:
Re: candlelight
very nice indeed
Re: candlelight
how did you do that…share to us bro..hehehe
Re: candlelight
thanks for your reply. at first i tried to do it in 3d but because light has the gradient its really difficult to accomplice therefore. i jsut made a 3d texture with opacity map. thesame map i used for emmisive layer. then i added an additional vray rectangular light. to explain the technique im attaching the screengrab.
Re: candlelight
Another great lesson for all of us Professor! Thanks for sharing with us!
Re: candlelight
can you share the file?? ;D
Re: candlelight
awsome! very nice:)
Re: candlelight
thanks for your reply guys, ok later i will share the tutorial and the file.
Re: candlelight* Updated with Panda page2
Ok Bienhai(sketchucationforum) has shared kung fu panda, so i used it here to recreate the PANDANGO sa Ilaw- a cultural dance in the Philippines. so this one is called “KUNG FU PANDA-NGO” cheers. hope you like it.
kung fu panda starwars version. No postprocessing pure vray output.
hehehe, nomer, your making that panda show his full potencial, hehehe, very nice renders my friend, btw i like very much that movie. cheers
u said no postprocessing? how u did that blurr on light saber???
thanks teo
same concept as your IES ande. you must have a nice blurry opacity map with nice gradient. the concept was inspired from your opacity maps.
here are the saber texture and clipmap which i did in photoshop.
in order to create the effect. you need create a 2d plane parallel with the saber, then you create a vray link material (im using vray4su) add to the tranparency map the (clipmap)
do another emmisive layer and do the same.
the clipmap should be inverted and be sure to tick the background map. VOILA
this is my way of testing vray. again as much as possible i dont want to do post processing. the post process here is just adding the background behind.
Kwistenbiebel loves this light effect coming in front of the camera. so i did a test using the same concept.
bear with me with this. im enjoying the panda.
this is “The Incredible Panda’s dramatic entry”
