Candy Intruder
Here my final version of this image ( the wips are on Wip Area). :smiley:
Original image rendered with 6K Width.
  Corona V5. I got some crashes during the hi-res render using the V5 RC, but i guess there´s something with memory. But on the other hand, i have 32Gb of ram... A couple of times the render crashed on the Parsing step, but i just close and open the project again (Clean memory) and it render ok. :wink:
   PT + HD Cache.
Have you tried assert build?
Yes. Sorry, i forgot to mention, the first time i got those crashes i thought it was something irrversible, then i tried the Assert Build and everything worked ok, in this meantime a new Alpha5 RCx was released and i´ve installed the "Release version", open the project and the crashes are gonne, but after some Renders (over shading process) the crash occured again, but i´ve discovered that just opening Max again, and the maxfile again and render it, it runs ok. Then i did not re-installed Assert version again... But using it seems to be more stable.
One more Award/FrontPage (Gallery) on 3DTotal for me (and Corona). Tnks again Ondra ! :smiley: http://www.3dtotal.com/index_gallery_detailed2.php?id=5503#readers_comments
Let´s push Corona more and more to the buzz. :wink:
