the slow down happens locally on a single machine as well if the resolution is turned up. there is no displacement or subdivision surfaces.
I got the DR to work but it doesn’t seem that information is getting to all render nodes having some really strange things going on now.
it seems that Secondary rays are not being calculated for all surfaces on all machines. like I found that when I would loo at the RawGI none of the blocks were there for the DR machines.
I got around this by rendering the GI on a single machine and then using irradiance and LightCache that I saved to a file I could render and get GI values for every DR node.
But I’m still having a VERY strange problem. I still not getting reflection values from “SOME” surfaces in the DR squares.
look:
here is the DR map 3dm-defiant is the master machine.
it seems to also be different material no returned in different DR nodes.
