I’m on a deadline, of course, and I’m getting crashes every time after a seemingly random number of frames. It’s not a complex scene and I’ve gone through to check for problems.
It’s archviz exterior, just a domelight but also happens with Vray Sun&Sky.
It happens on several releases of 3.6 and that does not seem to make any difference. I saved the Vray.log and the last line was…
[2017/Aug/16|12:19:10] Setting up 8 thread(s)
[2017/Aug/16|12:19:23] error: UNHANDLED EXCEPTION: Rendering region (256,320)-(288,352)
Last marker is at ./src/globillummap.cpp, line 2149: GlobalIllumMap::buildLightMap() {1}
It’s happening with both Max2016 and 2018.
Tried my own settings, the default setting, and the Quick settings, all fail in the same manner.
First I would like to know if it is possible to send the scene for investigation.
If not maybe we have to try exclude stuff one by one in order to isolate at least in which area the culprit is but that would take some time since you have to run a separate render for each test.
Are you using something new into that scene comparing to all others that do you crash?
Since the error is in the GlobalIllumMap, did you try to render the scene without GI?
How long does it take to crash, a few minutes or hours?
What’s the RAM usage during the rendering?
I’ve also tried the following so far with no success or noticeable difference…
1.) render with an override material
2.) render with the 1 light off
3.) render with GI off and light off
4.) render with override, GI and light off
5.) reset to default render settings
6.) merge all into new scene
7.) merge few objects into new scene
8.)Tried all the different GI engines…
9.) all different combinations of 1-9, with nearly all or even no, objects isolated.
-Nothing new, no plugins aside from V-Ray.
-The 275-300 frames are taking about 25-45 seconds each.
-Sometimes it gets through nearly 30 to 100 frames and crashes.
-Sometimes it crashes after 1-6 frames.
-RAM usage was just up to 4.5GB (have 32) and 4.5 Boxx CPU was not used for other tasks during rendering.
-Rendering still images does not encounter the crashes.
It stars to look like a bug already, after so many tweaks and still nothing.
Please send us a link to the scene or request access to our FTP server at support@chaosgroup.com and we’ll see what’s going on.
Include a link to this thread for a reference.
So how long does it usually take to be given ftp access??
Requested on 8-18-2017 and have so far only received an email confirming that I requested ftp access…still waiting, while deadline is about to be missed.
Is it possible, that you are using one of the new I9 CPUs and/or you have 128GB Ram installed? I have the 7980Xe and running into the same issue on heavy scenes, all other workstations render fine.
Edit (I just saw it says setting up 8 threads, so it’s probably not an I9) but do you have 128 GB RAM installed? I was able to render one of the sequences that crashed previously by bringing down the memory clockspeed.
