Cannot save .max-file when render output has a network path
Hi. I was about to start testing Corona on our first real project and immediately hit a pretty big wall. This isn’t strictly a Corona error, but maybe someone has had the same problem:
Whenever I set a render output path/filename that is on out network and check “Save file”, in the common tab, I can’t save the max file. Max just gets stuck saving forever, even on empty scenes. I’ve tried several scenes and computers and get the same thing. I’ve never had this before since V-Ray saved the rendered images via its own frame buffer, not via Max’s built in “saver”.
Does anyone know what this is? Any tips greatly appreciated since I’d really like to use Corona on this project
Edit: It seems to happen when the max file OR the render output is on the network. Sigh
