CANNOT START ENSCAPE AT ALL
2025.02.17 15:47:59.497 | INFO | Log File Path: C:\Users\boonj\AppData\Local\Enscape/Logs/BootErrors\BootError_2025-02-17_15-47-59_18988_Native_SketchUp.log
2025.02.17 15:47:59.497 | INFO | Initialized Native Boot Error Logger: SketchUp
2025.02.17 15:47:59.497 | INFO | Build Target: win-x64
2025.02.17 15:47:59.497 | INFO | Configuration: Release
2025.02.17 15:47:59.497 | INFO | Version: 2024.0
2025.02.17 15:47:59.497 | INFO | Code Version: 2024
2025.02.17 15:47:59.497 | DEBUG | Source Project Folder: Enscape.Sketchup.Plugin
2025.02.17 15:47:59.497 | DEBUG | Searching for: Enscape.Sketchup.Plugin.2024.dll
2025.02.17 15:47:59.497 | DEBUG | Bin Sub Folder: Sketchup2024
2025.02.17 15:47:59.497 | DEBUG | Module Dir: C:\Program Files\Enscape\Enscape.Sketchup.Plugin.Host-net8.0
2025.02.17 15:47:59.498 | INFO | Starting dotnet…
2025.02.17 15:47:59.498 | INFO | Entry Assembly: C:\Program Files\Enscape\Enscape.Sketchup.Plugin.Host-net8.0\Enscape.Sketchup.Plugin.2024.dll
2025.02.17 15:47:59.498 | INFO | Assembly Qualified Type Name: Enscape.Sketchup.Plugin.EnscapeSketchupPlugin, Enscape.Sketchup.Plugin.2024
2025.02.17 15:47:59.498 | INFO | Global Runtime: C:\Program Files\dotnet
2025.02.17 15:47:59.498 | INFO | Runtime Root: C:\Program Files\dotnet
2025.02.17 15:47:59.498 | INFO | Runtime Prefix: dotnet-runtime-
2025.02.17 15:47:59.498 | INFO | Runtime Id: win-x64
2025.02.17 15:47:59.498 | INFO | DotNetExe: dotnet.exe
2025.02.17 15:47:59.498 | INFO | Library Name: hostfxr.dll
2025.02.17 15:47:59.499 | TRACE | MajorMinorPatch Search Dir: C:\Program Files\dotnet\host/fxr\6.0.8
2025.02.17 15:47:59.499 | TRACE | MajorMinorPatch Search Dir: C:\Program Files\dotnet\host/fxr\8.0.10
2025.02.17 15:47:59.499 | TRACE | MajorMinorPatch Search Dir: C:\Program Files\dotnet\host/fxr\8.0.13
2025.02.17 15:47:59.499 | DEBUG | Global Host Fxr Path Check: C:\Program Files\dotnet\host\fxr\8.0.13\hostfxr.dll
2025.02.17 15:47:59.499 | INFO | Host Fxr Path: C:\Program Files\dotnet\host\fxr\8.0.13\hostfxr.dll
2025.02.17 15:47:59.499 | INFO | Runtime Config: C:\Program Files\Enscape\Enscape.Sketchup.Plugin.Host-net8.0\Enscape.Sketchup.Plugin.2024.runtimeconfig.json
2025.02.17 15:47:59.503 | INFO | Host Fxr Library Loaded.
2025.02.17 15:47:59.503 | DEBUG | Host Fxr Init: True
2025.02.17 15:47:59.503 | DEBUG | Host Fxr Runtime Delegate: True
2025.02.17 15:47:59.503 | DEBUG | Host Fxr Close: True
2025.02.17 15:47:59.503 | INFO | Host Fxr Calling: init
2025.02.17 15:47:59.513 | INFO | Host Fxr Calling: getRuntimeDelegate
2025.02.17 15:47:59.605 | INFO | Host Fxr Calling: close
2025.02.17 15:47:59.605 | INFO | Core Clr started.
2025.02.17 15:47:59.685 | DEBUG | Module Path: C:\Program Files\Enscape\Enscape.Sketchup.Plugin.Host-net8.0\EnscapeSketchupPluginHost.so
2025.02.17 15:47:59.685 | INFO | Starting Enscape…
Enscape not starting. stuck at 50% Exporting Materials. ive tried all possibilities of updating my GPU driver according to the info from website Enscape.com. ive tried uninstalling and reinstalling. my GPU is RTX 4060 with a driver version of 572.42. Ive tried looking at NVIDIA control panel and setting to make sketchup run on GPU. i dont have any on board motherboard integrated graphics.
I tried resorting to Chatgpt. Installed a new version of .NET 8.0 still didnt work.
Also something wierd. the Hardware features for RTX options are greyed out. Im not sure if this is a licensing Issue or a Hardware Issue. Sketchup does seems to run on GPU options fine.
When Enscape disappears after failing to startup, it is still running in Task Manager.
I was able to use Enscape two months ago, but then this error came up suddenly and i couldnt render my projects properly at all. Please help
Hi @jack_boon and welcome to our Forum.
Right away thanks a lot for already having submitted a dedicated report to our support team alongside. I can see this thread has been set to resolved so I reckon you were also able to circumvent this issue? Otherwise you can simply stay tuned for a further response from our official support team via the case itself.
For anyone facing similar issue. I’ve solved the issue by running sketchup as Adminstrator…
RTX features also came back online. Everything working fine.
If the fix is running the app as admin, that will be a problem in office environments where users do not have admin rights.
