Hi, I have a student license. However, I’m not able to activate it as the network connection always fails. I tried everything I found online, never works. I’m not even using a proxy so I don’t understand the menu…
Help :')
Help :')
@florencepm , welcome to our Forum.
Of course you mentioned you’ve tried everything but just in case you haven’t already, please also try to add the exceptions detailed in the following article to your firewall (especially if you’re using a third party application for that):
https://learn.enscape3d.com/blog/knowledgebase/proxy_firewall/
If that simply makes no difference, definitely also submit a feedback report with log files as detailed here, which will reach our technical support team directly: https://learn.enscape3d.com/blog/knowledgebase/using-the-feedback-button-win-rhino/
Generally whenever you experience technical issues like this, feel free to simply submit a report this way whenever and we’ll be able to assist you as quickly as possible.
