Can't Cancel
I’ve replaced my users folders under - AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU with another user, and the cancel works perfectly. So its something in there, but I can not work out which file for love nor money! I’ve been through replacing 10’s of files with other users. I think its an issue in the 3dsmax.ini file.
Amazingly, I’ve found it!!!
Its been the autosave in the Vfb history settings. Every time I cancel/finish a render, its sat there saving a massive VRIMG file. Turned it off and works perfectly!
Hope this helps others.
thanks…
where excactly disabled the autosave in vfb settings?
You open the Vfb then click the history btn, then at top right there’s a setting btn (you have to turn on history top left first). In there you set the save location, save, and autosave. I think autosave should be off by default, as I wasn’t using the history function and was having issue with the autosave.
Mark
hmm… thanks, but it seems thats not the cause on my side, why there is a lag of a few seconds after rendering is canceled.
It might be a good idea to send your scene for investigation.
Sometimes slow down might occur because Vray needs some time to free up the memory.
interesting thread…while considering mentioning the same bummer lag after a cancel, I just had a thing happen when everything seemed okay after a cancel, and max was responsive, but I could not close the VFB.
Everything behaved normally, except not being able to close the VFB. Required saving copy, and closing max to resolve.
Initial “Cancel” was fine, but after cancel button pressed, max was shit (unresponsive) for at least 30-60 seconds.
This was using max2014 x64 vray 2.4
-dynamic memory used (but no displacement in scene, but a few forests, grass, and sim.)
-render res was at 1400x788
-noticed, after rendering was complete, RAM usage did not drop but stayed quite high (8-11GB) in task manager
Is there a setting somewhere to make Vray clear the RAM after each render??
Thanks in advance…
edit: Sorry, cannot send the scene
okay, at least for my problem, it was solved (for the moment) by exiting and reopening 3dsmax…still stange
Vray frees the memory after each render, so there might be something else in Max for example that stays in memory.
By the way have you got this behavior on other scenes or it is just on this one?
You could try to hide some of the groups like forest , grass , simulations and etc in order to narrow down the issue.
For me, I think it was due to making some tracing planes and then increasing viewport bitmap performance to 4k.
I set it back to 512 and the lag seems almost not noticeable…I wish that setting had a reminder or something!
you will be lucky if max came back, mine became unresponsive endlessly…
